Clyde Epperson Posted May 30, 2017 Report Share Posted May 30, 2017 Car was running at 3000 rpm turned off and it started right back up and was at normal rpm. Any ideas? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 31, 2017 Report Share Posted May 31, 2017 No commonly noted issues that would explain that. Possibly wiring/fuseboxes affected by heavy rain or high pressure carwash? Check PCM for codes tho doubtful it set any. Also make sure fuses & relays are snug in the underhood fusebox as well as the passenger compartment fuse panel. Quote Link to comment Share on other sites More sharing options...
