Allen0511 Posted May 26, 2017 Report Share Posted May 26, 2017 I want to install led tail lights on my 2013 Ford but I'm afraid that if I do would the turn signals still work normally even thought the lak of resistance p.s does anyone have aftermarket taillights did you have any issuses Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted May 26, 2017 Report Share Posted May 26, 2017 I assume you mean LED bulbs, not the whole assembly. if you do some research (assuming you don't know anything about next few lines I type) you can turn off the bulb out notification via a laptop program called Forscan and a OBDII device 1 Quote Link to comment Share on other sites More sharing options...
