Gortty-Pilot Posted May 25, 2017 Report Share Posted May 25, 2017 I have recently been having my iPhone SE phone connect and disconnect randomly from MFT. I only have this issue in the car, so I don't think its the phone. I have already unpaired and repaired my phone various times with MFT. Does anyone know if there is a single standalone Bluetooth radio/module that I could replace? Or would the Bluetooth radio be a part of the APIM, ACM, or other module? Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 25, 2017 Report Share Posted May 25, 2017 Try to test another phone before deciding it is a fault from the car. Do you have the latest update on MFT? Did you try to Master Reset MFT? Was your phone recently updated? may be that update isn't fully compatible, though I wouldn't think so. 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted May 25, 2017 Report Share Posted May 25, 2017 (edited) I have been having the same issues recently and am in the belief it is the android BT system in the phone that is having issues. The reason I have this opinion is when I check the file sharing section for connections in the phone the android BT will not allow me to connect the media (phone) part through the MFT. I select it and it deselects it. Edited May 25, 2017 by macbwt 1 Quote Link to comment Share on other sites More sharing options...
Gortty-Pilot Posted May 27, 2017 Author Report Share Posted May 27, 2017 Im pretty certain its not my phone. It stays connected just fine with other bluetoooth devices and even in my wife's Nissan Quest. Last night, I pulled the fuse (#29) and let MFT reboot. When it came back, I then did the MFT Master Reset through the System menu. I hope this was enough to clear any remaining Bluetooth gremlins, otherwise Im going to start looking for the Bluetooth radio/module. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 27, 2017 Report Share Posted May 27, 2017 Could still be the phone. Try a different phone with your vehicle. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted May 28, 2017 Report Share Posted May 28, 2017 Are you running the latest software for the SYNC system? Quote Link to comment Share on other sites More sharing options...
Gortty-Pilot Posted June 1, 2017 Author Report Share Posted June 1, 2017 I'm still having issues with the connection. I'm running Version 3.08 15128. The version has worked well for the past year, but its gotten progressively worse iver the past month. The phone section doesn't even show the Emergency Contact numbers in case if an accident. Quote Link to comment Share on other sites More sharing options...
Gortty-Pilot Posted June 4, 2017 Author Report Share Posted June 4, 2017 I was still having issues with a repeated failing Bluetooth connection, so I performed a few upgrades to my both my iPhone SE and to MFT Sync. I am now running iOS 10.3.2 (I had the most recent previous version), but figured why not update it. I also am now running Sync2 v3.10 - which I downloaded from the Explorer forums. I'm hoping that the new Sync version and iOS will both provide a better connection. On a 20 minute drive this evening, I did not notice one disconnect, whereas before I would have at seen my phone pairing/unpairing at least 3-5 times. Time will tell. Quote Link to comment Share on other sites More sharing options...
