2013 Edge keeps stalling at traffic light
rqb2001
Mileage? All city with High idle hours? 50K miles with all city and high Idle would indicate spark plugs. Change plugs clean TB and Intake. Check your Emissions purge valve also it should hold about 21 Vacuum if it is down below 7 change it. Also change the PCV valve when you change the spark plugs. Spark plug change should only take you an hour.
Stalls at traffic light and slightly rough idle
