snmjim Posted September 24, 2018 Report Share Posted September 24, 2018 posted here, they are a complete set...front and back, both appear to fit http://www.fordedgeforum.com/topic/24894-mud-flaps-guards-for-15-17-sport-trim/ Thnx for the link, much appreciated.. Quote Link to comment Share on other sites More sharing options...
NoDTMF Posted September 24, 2018 Report Share Posted September 24, 2018 Are you requesting my review & concurrence? Umm..I sent it to you earlier and you replied "Sure" so I assumed that meant post it! Quote Link to comment Share on other sites More sharing options...
snmjim Posted September 24, 2018 Report Share Posted September 24, 2018 (edited) Umm..I sent it to you earlier and you replied "Sure" so I assumed that meant post it! Don't recall however, to keep my senility factor in check can you please direct me to where I stated "Sure" so I can also get a reality check? BTW, I reviewed the edits/updates, apparently twice now, and they're definitely beneficial. I'm adding this one to my library of supporting Tech Docs, good job...??? Edited September 24, 2018 by snmjim Quote Link to comment Share on other sites More sharing options...
NoDTMF Posted September 24, 2018 Report Share Posted September 24, 2018 Don't recall however, to keep my senility factor in check can you please direct me to where I stated "Sure" so I can also get a reality check? BTW, I reviewed the edits/updates, apparently twice now, and they're definitely beneficial. I'm adding this one to my library of supporting Tech Docs, good job... my bad...I sent it to Special K for approval...... Quote Link to comment Share on other sites More sharing options...
snmjim Posted September 24, 2018 Report Share Posted September 24, 2018 (edited) Disregard, Ref post #181 Edited September 24, 2018 by snmjim Quote Link to comment Share on other sites More sharing options...
snmjim Posted September 24, 2018 Report Share Posted September 24, 2018 my bad...I sent it to Special K for approval...... Just as good if not better...in some cases...lol 1 Quote Link to comment Share on other sites More sharing options...
GB3 Posted May 31, 2019 Report Share Posted May 31, 2019 So I recently bought a '15 Edge Sport and am looking to lower it a bit. After having done quite a bit of research, most notably in this forum, it seems like H&R are the way to go. Curious though, what has it done to each of your overall ride qualities? It rides really well stock, like I'm riding on a pillow, but I'm assuming that has mostly to do with the shocks...would that be accurate? I understand it will get a bit more stiff, but don't want to compromise ride quality as it's my everyday car. I mostly drive around town/freeways. Any advice you can provide would be appreciated! Quote Link to comment Share on other sites More sharing options...
NoDTMF Posted May 31, 2019 Report Share Posted May 31, 2019 The ride is stiffer, but I now have more than 10K miles and I wouldn't go back. Far as I know, HR springs are the only springs. Drive for 100 miles after install and then get an alignment. I have 21" wheels. I have heard the 20" wheels can be a nice compromise since they will be a little softer. Quote Link to comment Share on other sites More sharing options...
Sage Posted May 31, 2019 Report Share Posted May 31, 2019 4 hours ago, NoDTMF said: The ride is stiffer, but I now have more than 10K miles and I wouldn't go back. Far as I know, HR springs are the only springs. Drive for 100 miles after install and then get an alignment. I have 21" wheels. I have heard the 20" wheels can be a nice compromise since they will be a little softer. Just curious, why drive for 100 miles before alignment? I know in years past people would say the vehicle would settle in, but does it actually? Quote Link to comment Share on other sites More sharing options...
always on edge Posted May 31, 2019 Report Share Posted May 31, 2019 It ‘settles’ as soon as the weight of the vehicle is on the springs. I had the springs installed 2 years ago and an alignment done at the time of install. I have had no problems whatsoever. 1 Quote Link to comment Share on other sites More sharing options...
Project_Edge Posted June 1, 2019 Report Share Posted June 1, 2019 (edited) I found on the Ford Parts website that the springs with the AWD and FWD are the same part numbers so I think I am gonna pull the trigger on these springs as well for my FWD Sport. I found another manufacturer call Godspeed (that has a rather poor reputation for quality), they state their springs are compatible for both versions as well FYI. So, question is... Is the install the same for FWD? Should I drop the rear subframe or is it easier with FWD? Edited June 1, 2019 by Project_Edge Quote Link to comment Share on other sites More sharing options...
NoDTMF Posted June 1, 2019 Report Share Posted June 1, 2019 I guess one could argue settles vs seated. If on assembly, the springs rotate away from their stops, driving around will over time will seat them. Does that affect alignment, probably not. In my case front was still aligned, my rear was “way out” apparently, seemed to drive fine. Quote Link to comment Share on other sites More sharing options...
always on edge Posted June 1, 2019 Report Share Posted June 1, 2019 I guess I’d argue if the issue is a spring that is not properly seated, the installation was bad. Think about springs like this - when you buy a new car, do you have to take it to get an alignment 100 miles after you’ve driven it off the lot? To the OP - the ride quality is negligibly less than stock. On ramps and twisties will be a helluva lot more fun with the springs versus without. Quote Link to comment Share on other sites More sharing options...
CRJ Posted June 15, 2019 Report Share Posted June 15, 2019 (edited) On the first page of this thread, there is a picture of a silver Edge with aftermartket calipers and rotors. Could someone help me find out more about these, or piont me in the direction of the owner of that Edge? I'd like to do the same to my 18 Sport. Edited June 15, 2019 by CRJ 1 Quote Link to comment Share on other sites More sharing options...
Donto Posted June 15, 2019 Report Share Posted June 15, 2019 28 minutes ago, CRJ said: On the first page of this thread, there is a picture of a silver Edge with aftermartket calipers and rotors. Could someone help me find out more about these, or piont me in the direction of the owner of that Edge? I'd like to do the same to my 18 Sport. 4th post from the bottom of page 1 he states that they are Rotora brakes. See: http://www.rotora.com/street-challenge/ When in doubt always refer to this thread: 3 Quote Link to comment Share on other sites More sharing options...
CRJ Posted June 15, 2019 Report Share Posted June 15, 2019 Thank you. I'm a new member, and have a little difficulty navigating through everything. Quote Link to comment Share on other sites More sharing options...
Xtra Posted June 15, 2019 Author Report Share Posted June 15, 2019 (edited) Hello CRJ, I saw you car and you have done a nice job with it . That is my car a 2016 Sport and those are Rotora Street Challenge Brakes. The fronts are 380mm =15 inch cross drilled 2 piece rotors with 6 piston calipers and the rears are 350mm = 13.7" cross drilled 2 piece rotors with 4 piston calipers. The brakes still retain ABS and the electric parking brake. I have had them on my car for about 2.5 years now and they have never given me problems. I run them hard in the canyons that I live next to . IE: Mulholland , The Snake , Stunt Road and many others, check them out on You Tube. I have run these roads with other Edges that have stock brakes and I can tell you the stock brakes gave up within 20 min on these roads overheating and fading. I can run all day with no problems. You need to talk to Loren @ Rotora tell and him Extra sent you from this forum and he will work with you on the price. They are expensive but Loren is a good guy and should save you a lot. The slotted rotors are not as sexy as the cross drilled IMO but are more durable, but again I have never had a problem with my cross drilled in the time I have had them . You can PM me if you wish. https://www.rotora.com/street-challenge Edited June 15, 2019 by Xtra 3 Quote Link to comment Share on other sites More sharing options...
CRJ Posted June 29, 2019 Report Share Posted June 29, 2019 On 6/15/2019 at 3:01 PM, Xtra said: Hello CRJ, I saw you car and you have done a nice job with it . That is my car a 2016 Sport and those are Rotora Street Challenge Brakes. The fronts are 380mm =15 inch cross drilled 2 piece rotors with 6 piston calipers and the rears are 350mm = 13.7" cross drilled 2 piece rotors with 4 piston calipers. The brakes still retain ABS and the electric parking brake. I have had them on my car for about 2.5 years now and they have never given me problems. I run them hard in the canyons that I live next to . IE: Mulholland , The Snake , Stunt Road and many others, check them out on You Tube. I have run these roads with other Edges that have stock brakes and I can tell you the stock brakes gave up within 20 min on these roads overheating and fading. I can run all day with no problems. You need to talk to Loren @ Rotora tell and him Extra sent you from this forum and he will work with you on the price. They are expensive but Loren is a good guy and should save you a lot. The slotted rotors are not as sexy as the cross drilled IMO but are more durable, but again I have never had a problem with my cross drilled in the time I have had them . You can PM me if you wish. https://www.rotora.com/street-challenge Today, I ordered a set of brakes from Loren. Did you do the install yourself? 1 Quote Link to comment Share on other sites More sharing options...
Xtra Posted June 29, 2019 Author Report Share Posted June 29, 2019 11 hours ago, CRJ said: Today, I ordered a set of brakes from Loren. Did you do the install yourself? Congratulations! Tell me about them . What color are the calipers and what disc did you get? Did you get the brake lines to go with them ? As for the install I live about an hour away from Rotora so I had Loren install them at the time of purchase. Sorry I can't help you with that . As mine was the first ever with the electric parking brake I do remember that to install/ mount it some minor mod to the car was done. Talk to Loran about that if it comes up during the install . They may have changed things by now. If you have the skills and tools you might go for it yourself otherwise any good shop can handle it. Quote Link to comment Share on other sites More sharing options...
CRJ Posted June 29, 2019 Report Share Posted June 29, 2019 6 hours ago, Xtra said: Congratulations! Tell me about them . What color are the calipers and what disc did you get? Did you get the brake lines to go with them ? As for the install I live about an hour away from Rotora so I had Loren install them at the time of purchase. Sorry I can't help you with that . As mine was the first ever with the electric parking brake I do remember that to install/ mount it some minor mod to the car was done. Talk to Loran about that if it comes up during the install . They may have changed things by now. If you have the skills and tools you might go for it yourself otherwise any good shop can handle it. He offered me 3 different options. OPTION 1: AXLE CALIPER FINISH DISC SIZE DISC TYPE Front 6-Piston M. Blue 355x32mm 3D Drilled, 2-Piece Rear 2-Piston M. Blue 350x29mm 3D Drilled, 2-Piece OPTION 2: AXLE CALIPER FINISH DISC SIZE DISC TYPE Front 4-Piston Red 355x32mm 3D Drilled, 2-Piece Rear 2-Piston Red 350x29mm 3D Drilled, 2-Piece OPTION 3: AXLE CALIPER FINISH DISC SIZE DISC TYPE Front 6-Piston Red 380x32mm 3D Drilled, 2-Piece Rear 2-Piston Red 350x29mm 3D Drilled, 2-Piece Quote Link to comment Share on other sites More sharing options...
Xtra Posted June 30, 2019 Author Report Share Posted June 30, 2019 (edited) Mine are the option three, 380mm 6 piston front and 350mm 4 piston rear . In fact those are photos of my car getting the brakes installed at Rotora. I have the OEM 21 inch rims. Edited June 30, 2019 by Xtra Quote Link to comment Share on other sites More sharing options...
Southerngravy Posted February 3, 2020 Report Share Posted February 3, 2020 So what would be the equivalent airbag size to these springs for the rear??? Setiously wanting Air Suspension like yesterday!!! Quote Link to comment Share on other sites More sharing options...
blownZ71 Posted March 8, 2020 Report Share Posted March 8, 2020 What is the largest tire size you guys have been able to run with these springs. I just upgraded to 285/35R22 on 22 x 9 Niche wheels +38 offset. Wondering if anyone is running a similarly oversized tire on these springs? Thanks, 1 Quote Link to comment Share on other sites More sharing options...
Xtra Posted March 8, 2020 Author Report Share Posted March 8, 2020 (edited) CRJ did you get the brakes ? Edited March 8, 2020 by Xtra Quote Link to comment Share on other sites More sharing options...
always on edge Posted March 8, 2020 Report Share Posted March 8, 2020 Pics or it didn’t happen... Quote Link to comment Share on other sites More sharing options...
