Recreational Flat Towing - 2017 Edge
Perhaps, yes. But I >think< that power to the OBD port keeps SYNC alive and does not affect the servos or electro-mechanicals that control trans operations. I could be wrong on that and more research would be necessary before I'd consider a 4 down tow, but that is how I understand it. With the battery disconnected the drive train system intelligence is non-functioning and therefore a 4 wheel freewheeling tow is safe, but the minder would keep all the SYNC settings.
Maybe someone who is better versed on this can provide a better explanation. As I said, I think that's how it operates but I could be wrong.
If you're considering disconnecting the battery cable to tow (and you are required to reconnect after a certain period of hours, 6 if I remember) a battery switch would make this job much easier.
Examples:
BEP 701 Battery Switches - On-Off https://www.amazon.com/dp/B005DUUL9W/ref=cm_sw_r_cp_apa_2bnEBbF512VYA
NOCO ID220S 6V-24V 125 Amp Battery Disconnect Switch https://www.amazon.com/dp/B006EH9WUC/ref=cm_sw_r_cp_apa_RenEBbMR5VXYR
edit note; the original link was 404, added url to new link.
Edited by enigma-2
  • Like 3
  • 1 year later...
the battery will run down, and have to be recharged every so often (6 hour intervals IIRC). That is generally why people put on a TOAD of some sort.
http://www.rvnetwork.com/topic/122304-2015-ford-edge-toad-is-a-battery-charge-line-sufficient/
https://www.countrycoachforums.com/index.php?topic=17808.0
https://www.carprousa.com/car-pro-guide-to-dinghy-towing
I'm working through this right now. What really hit me was when I thought about starting the Edge with keyless ignition. I Have to hit the brake pedal first and that activates a considerable portions of the vehicle electronics. Then I thought about driving the RV and how often I hit the brakes; and each time I do I'm initiating the "start" sequence. I can readily see why the battery would run down.
Next question, once the battery is disconnected I guess you have to use the key to lock and unlock the car? Would an ODBII battery tender allow keyless entry to function?
And another questions. If you use the TOAD CHARGER (http://www.lslproducts.net/TC_Broch.pdf), what impact would that have on the system electronics, since you would still be activating the "start" sequence each time the brakes were applied.
