jmr061 Posted May 16, 2017 Report Share Posted May 16, 2017 The rear rotors on my 16 Sport are getting grooves in them. While I could get them replaced under warranty yet it has been my experience that OEM replacements would just do the same thing. Who has replaced their rear rotors on a 15+ and not had any issues with grooves or uneven wear? Basically looking for someone with the same experience to chime in and let me know what rear rotors are not going to fall victim to the same type of wear. I don't need drilled/slotted, just normal ones are fine. Thanks 1 Quote Link to comment Share on other sites More sharing options...
cv27 Posted May 17, 2017 Report Share Posted May 17, 2017 I recently noticed some quite deep grooves on the rears as well; fronts seem fine. 2015 with 27 000 km (close to 17 000 miles). Ford dealer does a complete car check on oil change. I now realize, after verifying all work orders since purchase, that they all indicate "brake check not done". Not what I expected. jmr0061 - I'm interested in your comment about "I could get them replaced under warranty".Won't the answer be "normal wear & tear" ? Quote Link to comment Share on other sites More sharing options...
akirby Posted May 17, 2017 Report Share Posted May 17, 2017 Brakes are covered for the first 12 months/12K miles IIRC. 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted May 17, 2017 Author Report Share Posted May 17, 2017 (edited) Covered up to 12 months/18,000 miles on a 2016 but OEM are junk and will just do the same so not going to go that route. I need to change the oil anyway so while I have it lifted I'll do the rotors too. Edited May 17, 2017 by jmr061 Quote Link to comment Share on other sites More sharing options...
Beezz Posted May 17, 2017 Report Share Posted May 17, 2017 (edited) I wasn't able to find anything aftermarket that actually fits the sport since we have slightly bigger rotors. Same goes for the pads. Powerstop has a kit that they say fits the 15 sport but when I tried installing it the rotors were 1 inch too big for the rear and 1 inch to small for the front, the widths were also off. We're stuck with OEM or the Rotora kit for now. There is some stuff from EBC and Stoptech that looked like it might fit but not 100% sure. Rockauto would be best place to find OEM equivalent rotors aswell (had none at the time). Rockauto Link : http://www.rockauto.com/en/catalog/ford,2016,edge,2.7l+v6+turbocharged,3330846,brake+&+wheel+hub,rotor,1896 Looks like there is replacements now, not sure on dimensions though. Note for others: When searching for kits sometimes use 2016 as the year instead of 2015 if you own a 2015 because for some reason 2015 sport still includes Gen 1 edges which have different rotor sizes. Even though sites specify it fits the 15 edge sport with the 2.7L. (applies for non sports too) See : http://www.tdotperformance.ca/2015-ford-edge-parts/performance-parts/brakes?part_type_filter_multi%5B0%5D=8658&pl=1 Edited May 17, 2017 by Beezz 1 Quote Link to comment Share on other sites More sharing options...
lildisco Posted May 17, 2017 Report Share Posted May 17, 2017 (edited) Interested in what you found for a 2016 non sport. I can't find pads or rotors anywhere. I've mainly stuck with brands I'm familiar with like powerstop, centric, hawk, etc. EDIT: Just re looked up everything again & they appear to be making rotors for the '16 non sports now. Couldn't find anything a few months ago Edited May 17, 2017 by lildisco Quote Link to comment Share on other sites More sharing options...
Beezz Posted May 17, 2017 Report Share Posted May 17, 2017 Yeah 2 months back there was nothing for the Gen 2's besides OEM. But double checked after I posted and it looks like Rockauto has ones that fit the Gen 2 now. The link shows that there are all sorts of rotors and pads now. The tdotperformance link shows there are kits, but the dimensions dont match with the 15+ Gen 2's Quote Link to comment Share on other sites More sharing options...
jmr061 Posted May 17, 2017 Author Report Share Posted May 17, 2017 I went ahead and ordered Bosch QuietCast™ Premium Disc Brake Rotors 3 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted June 1, 2017 Author Report Share Posted June 1, 2017 (edited) Don't order the Bosch rotors. They say part # 20010394 is for the 16 Edge....well the bolt pattern is wrong and the diameter is too big. Waiting for a call back from Bosch to get it correct hopefully. If I would have recalled when I was researching the part # it said it fit the Taurus too....from experience I know the Taurus and Edge have different bolt patterns but of course at the time it didn't register in my mind. Got a call back...mistake in their application catalog. They don't make any that fit. NICE!!! Edited June 1, 2017 by jmr061 Quote Link to comment Share on other sites More sharing options...
lildisco Posted June 1, 2017 Report Share Posted June 1, 2017 Working on my Centric Rotor at the moment & to see if they're the correct size Quote Link to comment Share on other sites More sharing options...
jmr061 Posted June 1, 2017 Author Report Share Posted June 1, 2017 BTW there was no apology or anything. Just send them back where you got them they said. A simple sorry we made a mistake would have been nice. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 1, 2017 Report Share Posted June 1, 2017 Quote Link to comment Share on other sites More sharing options...
lildisco Posted June 1, 2017 Report Share Posted June 1, 2017 (edited) Centric Rotor part #12561118 are the correct part # for the Fronts on A NON SPORT, not that it helps you any.... Edited June 1, 2017 by lildisco 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted June 24, 2017 Author Report Share Posted June 24, 2017 Ended up replacing the pads with Wagner ThermoQuiet and the rotors with Raybestos 681013. Was a fairly simple job with the right parts. One rotor came off hard but the other slid right off. 3 Quote Link to comment Share on other sites More sharing options...
1STSFG Posted September 23, 2017 Report Share Posted September 23, 2017 Hey Jason, how about a brake review? Thanks! Quote Link to comment Share on other sites More sharing options...
1STSFG Posted September 23, 2017 Report Share Posted September 23, 2017 Did you do a weight comparison on the OE rotors and the Rays? 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted September 26, 2017 Author Report Share Posted September 26, 2017 Sorry this site doesn't seem to send me notifications about replies....the replacement rotors/pads haven't been on too long but they are just fine. No issues. I did not weigh them. 1 Quote Link to comment Share on other sites More sharing options...
Johnm Posted January 19, 2018 Report Share Posted January 19, 2018 2016 sel awd. Also have had rear rotors with deep grooves. Original rotors replaced by dealer, replacement rotors and pads now grooved within 4500 miles. Seems as though there should be a tech service bulletin on this but can't find anything. Quote Link to comment Share on other sites More sharing options...
