We just started the sale on a 2014 Edge with the newer IKT type ignition key. Is this just a normal 40 bit key that has been in use since 2000? I just had a discussion with the sales manager. I told him that the key is cheap enough and i would take even a non IKT.
2014 is 80 bit. I would suggest not purchasing a car from any dealer without two fully working keys as they came from the factory. Also make sure those are the only ones programmed to the vehicle. All too often dealers sell vehicles with only one key and there is another fully functional one floating around.
I'm trying to get the dealer to sell it with a second key. Thank you for the update. Have you tried Key programming with ForScan, or is that too risky?
So these are 80 bit keys.
5912560 5912512
These seem to be the Strattec part numbers listed as compatible with a 2014 Ford Edge that I am in the process of purchasing. Unfortunately it's coming from a Chevy dealer, and I am loosing the battle to have them to include a second key at no extra cost.
Edited by thesavo
