atekido Posted May 12, 2017 Report Share Posted May 12, 2017 either im blind or just not looking in the right spot but i cannot find anything mentioning the RPM limit. I'm assuming the redline on these vehicles are not at the 4750 rpm listed for its peak HP as that seems fairly low but i guess i could be wrong. so does anyone happen to know what is the redline for the RPM? This mainly just for parameters in my Torque app to get accurate readings. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted May 12, 2017 Report Share Posted May 12, 2017 either im blind or just not looking in the right spot but i cannot find anything mentioning the RPM limit. I'm assuming the redline on these vehicles are not at the 4750 rpm listed for its peak HP as that seems fairly low but i guess i could be wrong. so does anyone happen to know what is the redline for the RPM? This mainly just for parameters in my Torque app to get accurate readings. 6100 I believe 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 13, 2017 Report Share Posted May 13, 2017 I would guess around 5,800 because of the turbos. But it doesn't really by matter because the PCM will ebstablish its own limits due to several factors. Can't say on the 2.7 but on the 3.5l the power drops off dramatically after 5k (fwiw). 1 Quote Link to comment Share on other sites More sharing options...
junehhan Posted May 13, 2017 Report Share Posted May 13, 2017 Redline is right around 6000, but actual WOT shift points are variable as they seem to depend on other factors such as vehicle loading and what grade you are accelerating on. I have seen WOT shifts as low as 5500rpms and as high as 6100. The 2.7 appears to actually do a pretty good job all the way to redline where it is generating the full 17lbs of boost from the data logs that I have seen. While it is not peaky like an old school Honda 4-pot, it actually does decent up top compared to the 2.0, 2.3, or 3.5 Ecoboosts. Chris Larsen will have to chime in as he has probably done more data logging than anyone else on these Sports. 1 Quote Link to comment Share on other sites More sharing options...
atekido Posted May 14, 2017 Author Report Share Posted May 14, 2017 Yall were right on the money. I logged the RPM in Torque and i hit 6114 as a peak RPM and hit 18 psi in boost, 2 Quote Link to comment Share on other sites More sharing options...
