atekido Posted May 12, 2017 Report Share Posted May 12, 2017 I did some searching and couldn't find specifics on what turbos are being used in conjunction with the 2.7. was just curious on the brand/size. Also is it even possible to put in larger turbos or is that not an option? I had read the 2.7 has a little different setup with how the turbos are bolted in vs most setups. I plan to get a 2015 Edge sport Tomorrow and im just thinking about what things i may modify if its possible. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 12, 2017 Report Share Posted May 12, 2017 Tune it. Going more than a tune and I believe you risk seriously damaging the drivetrain, mainly the transmission & PTU. As some members already did, a tune will add a lot to the 2.7L. 1 Quote Link to comment Share on other sites More sharing options...
atekido Posted May 12, 2017 Author Report Share Posted May 12, 2017 Yea I plan on getting it tuned. just was curious about the actual products that make up the turbo setup. this is probably a dumb question.. what does PTU stand for? ive only ever driven rwd muscle cars and can't recall seeing those 3 letters haha. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 12, 2017 Report Share Posted May 12, 2017 Power Transfer Unit, or I read sometimes it's called a Power Take-off (PTO). Basically, it's like a differential between the transmission & rear diff. It is bolted behind the transmission, then sends power to the rear via the drive shaft. 1 Quote Link to comment Share on other sites More sharing options...
atekido Posted May 12, 2017 Author Report Share Posted May 12, 2017 Ohh ok i guess I havent ever referred to it as that so it had me thinking it was something spefific to AWD lol. thanks for the info. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted May 12, 2017 Report Share Posted May 12, 2017 turbos are really small garret, f150 uses borg warner. not much room to work with to install a bigger turbo. If the edge your getting is fwd, you wont have any ptu issues. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 13, 2017 Report Share Posted May 13, 2017 The PTU/PTO is only on AWD (vehicles that are based on FWD). So yes, your Sport will have it since it is an AWD,if I recall correctly, 2016+ Sport comes only in AWD. Only 2015 models came in FWD or AWD. 1 Quote Link to comment Share on other sites More sharing options...
Denny Gaughan Posted May 13, 2017 Report Share Posted May 13, 2017 (edited) could this be it? https://www.turbobygarrett.com/turbobygarrett/turbochargers/gt2871r Ā Here's an image of it http://www.ebay.com/itm/Genuine-OEM-Ford-Turbocharger-Assembly-BC3Z-6K682-B-/301962213584 Edited May 13, 2017 by Denny Gaughan Quote Link to comment Share on other sites More sharing options...
Beezz Posted May 15, 2017 Report Share Posted May 15, 2017 If i recall correctly the rear turbo is visible from underneath the car and there is a product code on it. Here's the ford part numbers, maybe they'll help. http://www.discountfordpartsfromsoundford.net/FPSS-2016-Edge-Sport-Turbocharger-Components-s/422827.htm 1 Quote Link to comment Share on other sites More sharing options...
atekido Posted May 15, 2017 Author Report Share Posted May 15, 2017 oh cool thanks. I have yet to get under the vehicle minus a quick inspection. Quote Link to comment Share on other sites More sharing options...
Ray Heath Jr Posted May 19, 2017 Report Share Posted May 19, 2017 Just for clarity it is a PTU, Not PTO. A PTO is something used to divert engine power to auxiliary devices, like pump, generators, buckets, on larger vehicles. F250's and above are typically capable of this, not sure if the newest 250's are or you have to go to a 450 to get the function. Quote Link to comment Share on other sites More sharing options...
