edgejay33 Posted April 18, 2017 Report Share Posted April 18, 2017 sorry if this was posted somewhere else. anyway there is a rattle when starting off slow. its coming from the rear passenger wheel area. As the car starts out the clunking gets faster and it doesn't stay consistent with the spin of the tires just a gradual rattle. After 40-45 MPH it stops as if centrifugal force causes it to stop. It rattles and clunks when going over bumps and railroad tracks. It's a metallic rattle. I've looked underneath the car and to me it looked fine. The car steers fine and does not vibrate at all. It doesn't rattle in reverse or braking unless you hit a bump. Any help is useful thank you. Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted April 19, 2017 Report Share Posted April 19, 2017 If you have the chrome clad wheels you may have some debris between the wheel and the cladding. mactford edge on you tube has some video of the removal procedure. If you remove the offending wheel and roll it by itself you can tell if the noise is coming from the wheel of somewhere else. 2 Quote Link to comment Share on other sites More sharing options...
