Looking to replace stock rims
PH1LLYSPORTS
First, they're wheels not rims. The easiest way is to plastidip your current wheels. If you don't like it you can take it off or redo it any time you want and it usually looks pretty good.
If you want new wheels use tirerack.com and it will show you the wheels that fit your vehicle - just make sure you're getting the same diameter wheel as the current one and you can reuse your tires (17", 18", etc.). You can get this from the last 2 digits on the current tire size (e.g. 265/40R20 - 20" wheel).
If you go with some other wheel that doesn't say for sure it fits the Edge you'll need to check the bolt pattern and the offset to make sure it fits.
