wolfman78 Posted April 5, 2017 Report Share Posted April 5, 2017 2008 Ford Edge Limited 175,000 Anyone have this problem? Started to over heat 2 months ago puked all fluid out of reservoir and kicked out a cylinder overheat code. Refilled reservoir cleared codes and no problem for 2 months. Puked out again last night while my daughter was idling for 10 minutes. Refilled reservoir drove again no problem. I have been told could be the fan not coming on to cool while at idle? Have not checked the A/C yet if it comes on. Any help would be great... Quote Link to comment Share on other sites More sharing options...
akirby Posted April 5, 2017 Report Share Posted April 5, 2017 http://www.fordedgeforum.com/topic/12731-radiator-fan-assembly-replacement-procedure/page-2?hl=%2Bradiator+%2Bfan&do=findComment&comment=115147 Could also be the water pump if it loses coolant before it overheats. 1 Quote Link to comment Share on other sites More sharing options...
wolfman78 Posted April 5, 2017 Author Report Share Posted April 5, 2017 Could it be in need of a coolant flush? Air in the system thermostat? Quote Link to comment Share on other sites More sharing options...
macbwt Posted April 6, 2017 Report Share Posted April 6, 2017 Check the fans. Check the engine oil for signs of coolant in oil (oil changes to a chocolate milk color when mixed with coolant) if you have coolant in oil (stop driving it) Replace water pump 1800.00 dollars 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 7, 2017 Report Share Posted April 7, 2017 Does your temp gauge read in the normal zone? Quote Link to comment Share on other sites More sharing options...
