chefduane Posted April 4, 2017 Report Share Posted April 4, 2017 (edited) It did appear that you were saying that the pinch weld was used to jack the car. (Others inferred this also.) I was illustrating that that was not the case. And it is not the case. Edited April 4, 2017 by akirby personal attacks removed Quote Link to comment Share on other sites More sharing options...
KLinNBC Posted April 4, 2017 Report Share Posted April 4, 2017 It did not "appear" that I was saying the lifting is done by the pinch weld edge, I was absolutely saying that is the case. The lifting is completely and only by the lower edge of the pinch weld seam. The jack pad does NOT contact any part of the body other than the edge of the pinch weld seam. You are 100% wrong with respect to the 2015+ Ford Edge and the factory supplied jack. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 4, 2017 Report Share Posted April 4, 2017 Ok, guys, knock it off. I edited/deleted some posts. No more personal attacks including moderator insults. Chefduane - KLinNBC appears to be right for the 2015+ Edge and MkX. They do appear to use the pinch weld to lift the vehicle. This is completely different from the pre-2015 models that straddle the pinch weld. You're both right depending on the model year. 1 Quote Link to comment Share on other sites More sharing options...
Brucifer Posted April 4, 2017 Report Share Posted April 4, 2017 Ok, guys, knock it off. I edited/deleted some posts. No more personal attacks including moderator insults. Chefduane - KLinNBC appears to be right for the 2015+ Edge and MkX. They do appear to use the pinch weld to lift the vehicle. This is completely different from the pre-2015 models that straddle the pinch weld. You're both right depending on the model year. Everyone is in a pinch and all jacked up. Just need to release the pressure and let things come down. 2 Quote Link to comment Share on other sites More sharing options...
chefduane Posted April 4, 2017 Report Share Posted April 4, 2017 No problemo here. Quote Link to comment Share on other sites More sharing options...
