Blue Oval Posted March 17, 2008 Report Share Posted March 17, 2008 This may sound stupid, but where do I plug in my IPod? I tried using a USB cord and that didn't work. I see a AUX type input next to that, do I need to get that type of cord for it to read??? Then if that is it, what is the correct function on the Radio?? Thanks for any help. Doug Quote Link to comment Share on other sites More sharing options...
harley2199 Posted March 18, 2008 Report Share Posted March 18, 2008 plug it in to the usb ..then ether press media button til you get to aux and it will say usb or use the sync button an say usb and it will connect hope this helps Quote Link to comment Share on other sites More sharing options...
solas989 Posted March 18, 2008 Report Share Posted March 18, 2008 Go to SyncMyRide and register with your vin. This will get you all the manuals you need for your specific make up. It is different for those with Nav and those without. There is also a printed manual that came with the car regarding SYNC. Was your purchase used and you did not receive these? If so, that is where SyncMyRide will be very helpful for you. And yes, you plug it into the USB port and use the Media button to select USB. Solas Quote Link to comment Share on other sites More sharing options...
Blue Oval Posted March 18, 2008 Author Report Share Posted March 18, 2008 Go to SyncMyRide and register with your vin. This will get you all the manuals you need for your specific make up. It is different for those with Nav and those without. There is also a printed manual that came with the car regarding SYNC. Was your purchase used and you did not receive these? If so, that is where SyncMyRide will be very helpful for you. And yes, you plug it into the USB port and use the Media button to select USB. Solas This was a new purchase, and we do have the SYNC manual. I'm thinking that I need to use the headphone jack on the IPod and connect the other end into the small jack next to the USB, correct??? Like I said we tried using the USB cable and it asked to create text? I'll try again using your suggestions! Thanks Oval Quote Link to comment Share on other sites More sharing options...
akirby Posted March 18, 2008 Report Share Posted March 18, 2008 This was a new purchase, and we do have the SYNC manual. I'm thinking that I need to use the headphone jack on the IPod and connect the other end into the small jack next to the USB, correct??? Like I said we tried using the USB cable and it asked to create text? I'll try again using your suggestions! Thanks Oval Use the USB cable that came with the iPod and follow the instructions in the sync manual. You won't get voice control of the iPod if you only use the headphone jack. Quote Link to comment Share on other sites More sharing options...
Craiger Posted March 18, 2008 Report Share Posted March 18, 2008 Yes, the USB cable that came with your iPod...just plug n play! Quote Link to comment Share on other sites More sharing options...
Blue Oval Posted March 19, 2008 Author Report Share Posted March 19, 2008 Set it up with the USB cable yesterday and works great now, thanks!!!! Quote Link to comment Share on other sites More sharing options...
