Changed oil in PTU
bubbadewsky
I had the oil changed in the ptu today using a BG machine. Was able to suck out approx. 14 oz each time, we did a drain and refill two times. Run the engine and wheels in between changes. The 2014 Edge has 20,700 miles on it. The oil color looked amber almost like new motor oil and felt like new motor oil. Filled up with Royal Purple 75-140. I think I will change it every 20,000 mi. No reason to change sooner or later.. This could be just as easily done with a cheap vac. pump. Fill plug easy to get to. Took about two min. for the machine to suck out the oil.
Edited by bubbadewsky
  • 11 months later...
