commbubba19 Posted March 23, 2017 Report Share Posted March 23, 2017 So i've noticed that randomly, my 2016 Sport will turn the a/c on at startup. The thing is, it's not hot outside. I've had this happen when it's 45* in my garage or in the low 50's outside. When turning the car off, the hvac controls are as follows: Auto, 72, but i manually lowered the fan to 1. I do this pretty much daily, but the a/c thing happens maybe 2-3 times a month. Like I said, it's not warm and definitely not humid, but i'm trying to figure out why the car thinks it needs the a/c on. Anyone else notice this? Quote Link to comment Share on other sites More sharing options...
akirby Posted March 23, 2017 Report Share Posted March 23, 2017 I've had the same issue with my Fusion for the last 4 years. I think it's how the CD4 platform hvac works. Our 2016 MKX seems to work the same. I also like to keep it on 72 and more often than not the A/C will blow cold when you first start the vehicle even if it's below 60 outside. If you bump it up to 73 it stops. I thought maybe it was a bad sensor but then I noticed others reporting the same and on our MKX. I think it's just how it's programmed. Next time try bumping it to 73 at startup then back to 72 after a few minutes. 1 Quote Link to comment Share on other sites More sharing options...
