EdgeS16 Posted March 4, 2017 Report Share Posted March 4, 2017 Does anyone reset the ECU/PCM after installing a new tune just to let it start from defaults to learn the new values for that tune? Thanks Quote Link to comment Share on other sites More sharing options...
redlancer Posted March 5, 2017 Report Share Posted March 5, 2017 I would assume flashing the ecu does reset it. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 5, 2017 Report Share Posted March 5, 2017 I would say that is not 100% true. There are some parameters in the PCM that are retained despite a reflash; which ones depends on the type of PCM. The only way to really get the PCM to fully reset is with a KAM reset. Not a necessary step, but if you experience issues, may help resolve them. Quote Link to comment Share on other sites More sharing options...
GT500R Posted March 5, 2017 Report Share Posted March 5, 2017 Which tuner? You can do the KAM reset if you have an SCT device. Quote Link to comment Share on other sites More sharing options...
EdgeS16 Posted March 5, 2017 Author Report Share Posted March 5, 2017 Which tuner? You can do the KAM reset if you have an SCT device. I think the livernois can't do it, is there a way to do the KAM reset after loading the LMS tune, I know if you disconnect the battery maybe you can do it but sure what's the correct steps. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 6, 2017 Report Share Posted March 6, 2017 2 Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted March 6, 2017 Report Share Posted March 6, 2017 I would assume flashing the ecu does reset it. nope doesn't do it, shit flashing doesn't clear a lot of stuff tbh Quote Link to comment Share on other sites More sharing options...
Ray Heath Jr Posted March 6, 2017 Report Share Posted March 6, 2017 This just seems like a rough way to do it. You are basically killing the Capacitors quickly to clear the KAM. You could use FORSCAN to do it with out disconnecting ANY battery. Honestly, a slow draw by disconnecting the battery and letting it sit, would be a better method than described in this video. Clearing it via FORSCAN would by far be the best method. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 6, 2017 Report Share Posted March 6, 2017 Make sure to mention it in the comments section on his video Quote Link to comment Share on other sites More sharing options...
Ray Heath Jr Posted March 6, 2017 Report Share Posted March 6, 2017 Make sure to mention it in the comments section on his video I don't jump into YouTube discussions. He has a good channel, I actually subscribe, just think there are better ways. No doubt this will work. 1 Quote Link to comment Share on other sites More sharing options...
