DBDRVN Posted February 24, 2017 Report Share Posted February 24, 2017 Can someone explain to me why sometimes my accessory outlets are constant power and sometimes they are accessory switched? 2016 Ford Edge Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 25, 2017 Report Share Posted February 25, 2017 (edited) It is my understanding that the "engine off load shed" feature was not connected to the auxiliary power points (that is, they are always on). They are powered directly through the Battery Junction Box and not through the Smart Junction Box. http://owner.ford.com/how-tos/vehicle-features/center-console/powerpoints.html Unlike the 120 volt Power point the shuts off when the battery reaches 11 volts, these will completely drain the battery if allowed. Edited February 25, 2017 by enigma-2 Quote Link to comment Share on other sites More sharing options...
DBDRVN Posted February 25, 2017 Author Report Share Posted February 25, 2017 (edited) On 2/25/2017 at 1:49 AM, enigma-2 said: It is my understanding that the "engine off load shed" feature was not connected to the auxiliary power points (that is, they are always on). They are powered directly through the Battery Junction Box and not through the Smart Junction Box. http://owner.ford.com/how-tos/vehicle-features/center-console/powerpoints.html Unlike the 120 volt Power point the shuts off when the battery reaches 11 volts, these will completely drain the battery if allowed. If the car has been running upon cutting the car off the accessory outlet remains energized for a lengthy period of time (30 mins or more) it eventually cuts off. On the other hand. Once off...if the radio is powered on...the circuit cuts on...cut radio off circuit cuts off. You can cut radio on and off without keys by pressing on button. I want my device I use for work to come on and off with the switch but not to cut off an hour later. Fuse 23 shows as delayed accessory I may have to see if this operates the way I need it to. Edited February 25, 2017 by DBDRVN Quote Link to comment Share on other sites More sharing options...
