Starting issues
sealyons
On 11/20/2020 at 10:24 AM, Edge-y said:
So I’ve made a discovery. I normally don’t let my vehicles get below a quarter tank of fuel for obvious reasons. Well, I did it once last week and noticed that it stopped acting up when the fuel was very low. Filled almost all the way up from empty and it stated acting up again. So, I repeated the process and got the same results. It doesn’t act up when it’s running on low fuel. Still think it could the purge valve failure?
Did you ever figure this out?
I have replaced the purge valve, battery in the key fob and cleaned the mass air flow sensor.
ours is a 2010 sport
im tempted to get a new mass air flow sensor. Dealer could not figure it out. No codes.
