WWWPerfA_ZN0W Posted February 14, 2017 Report Share Posted February 14, 2017 2015-2016 Edge, Explorer, Mustang, and F-150 Various Engines – Oil Leak At Engine Oil Pressure (EOP) Sensor ThreadsSome 2015-2016 Edge with 2.0L Gasoline Turbocharged Direct Injection (GTDI), 2015-2016 Mustang and F-150 with 5.0L engine and 2016 Explorer equipped with 2.3L GTDI engine may exhibit oil leak at engine oil pressure (EOP) sensor threads.It is not required to replace the sensor if it is leaking from the threads.Remove and reseal the EOP sensor, refer to Workshop Manual (WSM), Sections 303-14.Check the oil level and top off as necessary.Refer to WSM, Section 303-01. Quote Link to comment Share on other sites More sharing options...
