TSB 16-0138 2.7L – 6F50/6F55 – BUZZ, HUM OR MOAN NOISE FROM THE ENGINE COMPARTMENT AT 40 KM/H (25 MPH)
Publication Date: October 7, 2016
LINCOLN:
2016 MKX
ISSUE:
Some 2016 MKX vehicles equipped with a 2.7L engine and 6F50/6F55 transmission may exhibit a buzz, hum or moan noise from the engine compartment at 40 Km/h (25 MPH) and above or at engine speeds from 2000 to 3500 RPM. This may be due to the transmission fluid cooler tube.
ACTION:
Follow the Service Procedure step to correct the condition.
SERVICE PROCEDURE
Replace the transmission fluid cooler tube. Refer to Workshop Manual (WSM), Section 307-02.
PART NUMBER PART NAME
G2GZ-7C410-A Transmission Fluid Cooler Tube
XT-10-QLVC Motorcraft MERCON LV Automatic Transmission Fluid
OPERATION DESCRIPTION TIME
160138A 2016 MKX 2.7L: Replace The Transmission Fluid Cooler Tube (Do Not Use With Any Other Labor Operations) 0.9 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
7C410 42
