Smart Charging USB ports
27Sport
Since the kids are always on their phones or iPads in the car I decided to install a couple Smart Charging USB outlets using all factory parts that's available in the newer Explorers. I suppose I could have just used adapters in the existing 12V outlets but that's no fun, plus the Smart Charging ones allow a faster charge, especially on the iPad's. I did the 2nd row version on my '15 Edge and simply transferred the whole panel to my '16. That portion required some trimming of the panel to allow the USB mount to fit where the 12V originally was. I decide to install another charging outlet in the front passenger area as I have an iPod continually plugged into one of the radio USB's and my phone plugged into the other.
2nd row outlets
23c1bb5a-929d-4351-a025-ed989d6b6eea_zps
Parts needed for charge ports, only 2 wire connections using the existing 12V wires.
39B52F12-AABD-41B6-970B-B7A80CE5D148_zps
Stock outlet in front passenger area
B6010D33-D2A9-470D-91EE-02F0AEE1634A_zps
Parts needed are the same, except I separated the dual USB wires, and used the single mounting plug that's used inside the center console of the '16+ Explorers
B7BC3FBF-B502-42D0-850D-9CDCFBF254CC_zps
Need to remove 2 side panels, simply pull out.
B537E395-7C06-4057-B619-D9B8E605C383_zps
Power converter tapped into the existing 12V plug
71C58BC7-81BD-45BF-AD1B-393B5032AE04_zps
Power converter secured inside console
4578D188-ECAD-45BA-84E1-FD5A178F058B_zps
Everything put back together, can be put back to stock at any time and took all of 10 min for complete install
9ED6E74A-7FFD-454F-9834-4CDEF05148E6_zps
  • Like 5
Would you happen to have part numbers for all the parts or if it comes in a "kit"??
Dual USB cable JL1T-14D202-GA
Dual outlet cover FB53-045N67-A ('16+ Explorer rear of console)
Single outlet cover FB53-R045N22-A ('16+ Explorer inside center console)
Power inverter GU5T-19J211-AA
Wiring connector for inverter WPT-982 (6U2Z-14S411-JB)
Only the 2 outer wires are used for power and ground. See pic above for power (yellow) and ground (black) as the service parts may have all the same color wires.
I got most of my parts on ebay so the outlet cover part numbers might be engineering numbers, but the dealer should be able to cross reference the service numbers.
  • 1 year later...
Resurrecting an older thread here, but I wanted something similar.
I have a 2017 Titanium Edge and I found that this usb car plug (below) worked perfectly and only costs $10 with no modification to the car.
https://www.amazon.com/AUKEY-Charger-Output-iPhone-Samsung/dp/B00M6QODH2
It fits into the front passenger and center compartment flush and the stock cover will close with the caveat that the door flap does catch on the edge of the USB plug. I remedied this but taking a knife and shaving a flat edge on the USB plug that faced the door hinge. Once I trimmed that up, it fits flush and the usb door closes perfectly. It's worth noting that the second row charging cover is a little bit bigger than the front passenger and center console so no trimming was necessary and the flap closes perfectly without any modification. I like this because it looks like the usb chargers are oem, the doors close all the way, and if I need to use something else in the adapter I can still remove the usb plug and plug something else in instead.
It's worth noting this one above will charge up to 2.4 amps for each port, which is faster than the 2.0 amp smart plugs that come with the car but are slower than the power IQ and Quick Charge 3.0 standards.
If you want a quick charge 3.0 capable port though to charge at 3 amps, Aukey also makes this guy (below). It has the same dimensional size as the one above that I have except that it's a single port 3.0 Quick charger. So you should be able to plug it in and still close the doors.
https://www.amazon.com/AUKEY-Charger-Charge-Samsung-Galaxy/dp/B01KZHKF4I
I also purchased a few LED usb plugs, because I liked the blue glow at night, that were supposed to be flush mount by Torras and Ainope and neither one of them actually fits flush. They're about 1/10th of an inch larger than the ones above and they both stick out so you can't close the doors (even the larger second row plug won't close).
Anyway, if someone wants a stock look without taking the car apart, the above should help.
  • Like 3
Bump. Anyone have part numbers or links to the dual usb outlet covers? I cant seem to find them
I found the part number for the dual usb outlet. FB5Z-19A495-AA
I puchased this and the outlet is far too big to fit the front passenger spot on my 2013 Edge. Maybe the space is a little bit bigger in the 2015+ Edge? It does appear it will fit the rear of the center console for the 2nd row. I will posts pics when i get around to installing
