Shifter light
So today I decided to run a USB charging cable behind the console pieces and come out the vents up top. It all went well with one exception...I lost my shifter lights. I saw the cable was loose but couldn't see in there well enough to see how or where it actually clipped in. Does anyone have a picture or diagram of where this goes and how it is secured?
Are you referring to the gear indicator in the dash adjacent to the speedometer, or the position indicator next to the shift lever by your right knee? My PRNDM indicator next my knee has never lit up. It is supposed to? I wonder if that has anything to do with why my Emergency Flasher soft touch switch (the little red triangle just above the CD slot) has never worked. Need to check fuse 29 to verify that, but perhaps the two are related.
Edited by chefduane
