WWWPerfA_ZN0W Posted January 29, 2017 Report Share Posted January 29, 2017 Does anyone know if there is a factory-set limiter on speed in Edge vehicles shipped to the Middle East? I am thinking this is a MyKey phenomenon, but maybe not? TIA! Quote Link to comment Share on other sites More sharing options...
lildisco Posted January 29, 2017 Report Share Posted January 29, 2017 It is usually what the oem tires are rated for. Usually around 100mph 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 29, 2017 Author Report Share Posted January 29, 2017 I have someone saying 70 mph or so. I dont know if the OEM tires are rated at that tho. Quote Link to comment Share on other sites More sharing options...
lildisco Posted January 29, 2017 Report Share Posted January 29, 2017 If manufacturered in Canada/USA, I'd imagine that they'd follow those specs & in the USA speed limits (in some areas are over 80 mph), I'd say it's around 95-100. But going through the inspections over in the middle east, they may impose a different speed limitation in the computer. But, usually it for what the oem tires are rated at. They don't want you to be traveling at 90 on tires rated 70mph (unlikely rated that low) & blow up while driving down the road. Remember that tires rated at 95 can go for a short while above 95 & not have a problem, but if you're traveling over 100 for an extended period of time (like 10+ minutes) the integrity of the tire will likely degrade & cause a pretty bad accident. 1 Quote Link to comment Share on other sites More sharing options...
Beezz Posted January 29, 2017 Report Share Posted January 29, 2017 Could check the vin on http://www.etis.ford.comif they have a limiter it should be included on the build data. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 29, 2017 Author Report Share Posted January 29, 2017 Have never seen a limiter mentioned on any of the build sheets I have seen on ETIS. I suppose that's optional/"need to know" info, can be pulled up from the PCM for sure, since tuners can limit the limiter 2 Quote Link to comment Share on other sites More sharing options...
Beezz Posted January 29, 2017 Report Share Posted January 29, 2017 deep down for my vin it does say " Less Preprogrammed Speed Limit " "Less Electronic Speed Limitation" maybe ford didn't include that info for Gen 1? and LOL "limit the limiter" 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 29, 2017 Report Share Posted January 29, 2017 Throw a set of Michelin Premier LTX's on and you have 148mph tires then you can floor it. It will never reach that speed. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 29, 2017 Author Report Share Posted January 29, 2017 For my 2007, I see Less Safety Packs and Less Ambient Temp/Speed Pack but that's it. No mention before 2014 either. But you are correct, for 2015, they do display the 2 parameters you mentioned, interesting! Why would they do that? Always there, just never displayed? Quote Link to comment Share on other sites More sharing options...
Beezz Posted January 30, 2017 Report Share Posted January 30, 2017 Speed pack may very well be what they called it before? Maybe there isnt even a limiter on any of them lol, no one is about to do 148+ mph in an edge.... normally... (I hope xD) 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 30, 2017 Report Share Posted January 30, 2017 Middle East Fords are speed limited, usually the same as US versions or a little higher. I think the Edge/MKX here can go to around 115~118 mph (185~190 KPH), I don't recall trying it myself. Also, all Middle East Ford vehicles from North America get what they call in ETIS "With High Ambient Temp/Speed Pack", usually it meant better cooling, better pads & better tires. For example, with the Crown Victoria we got police spec tires/radiator/pads. For the Edge we got the towing package components, but the same tires. 1 Quote Link to comment Share on other sites More sharing options...
chefduane Posted January 30, 2017 Report Share Posted January 30, 2017 (edited) My Goodyear Eagle RS-A's are Speed Rated H - 130mph. Edit: Just did some checking... automobile-catalog.com/professcars estimates 136mph top speed with 4235lbs curb weight, full fuel tank, and 200lbs load theoretical top speed without governor. Edited January 30, 2017 by chefduane 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 30, 2017 Author Report Share Posted January 30, 2017 Thanks for the clarification, omar, much appreciated! Quote Link to comment Share on other sites More sharing options...
akirby Posted January 30, 2017 Report Share Posted January 30, 2017 On 1/30/2017 at 10:22 AM, Ntrain2k said: My 2011 has a limiter at 112 MPH. I hope that was verified on the track and not the street...... It's going to be based on the tires or other vehicle components not local laws or speed limits. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted January 30, 2017 Report Share Posted January 30, 2017 On 1/30/2017 at 5:10 PM, Ntrain2k said: Let me worry about my verifications. You worry about yours. If your verifications are on public roads then that is very much MY business since you're putting me and my family and countless other innocent strangers at risk. Obviously you can do what you want but don't say it's none of our business on public roads. On 1/30/2017 at 5:10 PM, Ntrain2k said: The limiter is based on more than tires and vehicle components. A TON of them are limited to speeds less than components/tires are capable of. Example? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 30, 2017 Author Report Share Posted January 30, 2017 Lets stay on topic please, this topic is intended to be informative, not combative. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 30, 2017 Report Share Posted January 30, 2017 Those aren't Fords. And I'll leave it at that. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 30, 2017 Report Share Posted January 30, 2017 The topic is titled "does Ford limit speed on the Edge". So excuse me for trying to answer within that context. Quote Link to comment Share on other sites More sharing options...
chefduane Posted January 30, 2017 Report Share Posted January 30, 2017 (edited) Not any more: "..but this time Ford has dumped hi-test in the terminal-velocity discussion by claiming a 200-mph top speed for the 2013 GT500. In fact, 202 mph, supposedly observed on a test run at the circular 7.8-mile circular Nardo Ring in southern Italy." Source: Car and Driver - Flat Out! We Gun for 200 MPH in the 2013 Ford Mustang Shelby GT500. August 2012 Issue. The article does say that 2011 and earlier GT500's had limiters at 155 but that their test driver was able to get the 2013 to 189+change but not quite to 190. Pretty damn fast! In a previous career I drove a 1998 Olds Alero Indy Pace Car around the Indy 500 at 100mph (track official said that was max allowed for a civilian driver) and that was fast enough for me! Got to do 5 laps - one of the best driving days I've ever had!! Edited January 30, 2017 by chefduane 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 30, 2017 Author Report Share Posted January 30, 2017 Ntrain, akirby, I would appreciate it if you could clean up your respective posts in this thread, your opinions are valued, but they need to also not derail future readers of this thread. Thank you. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 31, 2017 Report Share Posted January 31, 2017 On 1/30/2017 at 11:41 PM, Ntrain2k said: Will do, we will see if he does. Way to get in one more jab. Quote Link to comment Share on other sites More sharing options...
ipla68 Posted September 29, 2017 Report Share Posted September 29, 2017 Top speed definitely limited in CA cars... 105 Quote Link to comment Share on other sites More sharing options...
