Keys won't program
I can't get my 2013 edge to program keys. I went through the procedure multiple times with no success. I went to the dealer and they couldn't do it either. They finally got by using their scan tool and forcing the car to program but they didn't know why they had to do that. Well that doesn't help me. I need it to go into programming mode. Can anyone help?
Okay lets start over. I have the two original keys with fobs for the car. I wanted to install an aftermarket remote start. To finish programming the remote start the vehicle needs to be put into the key programming mode which it won't do. To figure out whether or not it was a remote start problem I decided to have a 3rd standard key made for the car. When I and the dealer tried to program that key, the car would not do it with the standard procedure that is in the owners manual. The dealer had to force the car into program mode with their scan tool to program the 3rd key with no fob. They also didn't know why they had to do it that way. So until I can get the car into key programming mode I can't program other keys or my remote start. The process I need to work is the one that programs the chip in all keys whether it has a fob or not.
This is a remote (pun not intended) possibility. If one of the keys is not original and is a clone of the other, the car will see them as the same, instead of two different keys, and not go into programming mode.
Are you the original owner of the car?
That's an excellent point and exactly why I don't recommend using a locksmith to program a second key because some do simply clone the first key which will lead to exactly the situation described here.
The locksmith should tell you if he is cloning or programming. If he doesn't come out to your car, he is cloning.
