David Young Posted May 24, 2020 Report Share Posted May 24, 2020 (edited) 1 hour ago, omar302 said: Ford now sells their switch separately (link) (without the whole shifter). This was part of TSB 17- 2219 (link). I'll order one when and if the 2 switches I just ordered go bad. Edited May 24, 2020 by David Young Quote Link to comment Share on other sites More sharing options...
David Young Posted May 30, 2020 Report Share Posted May 30, 2020 Replaced the switch today. The second time is easier . We'll see how long this one last. If this one only last a couple years, I'll order the one from Ford. I'll have an extra switch if the Ford one goes bad is a couple years Quote Link to comment Share on other sites More sharing options...
DD2000GT Posted August 29, 2020 Author Report Share Posted August 29, 2020 (edited) I had to look up my old post to get the part numbers again as one of the microswitch posts broke allowing the switch to pivot when placed into park and causing this message to appear again after two years since last fixed. Looks like quite a few people have had this issue since my initial post - glad to have saved so many people money and frustration from this little switch. Buy extras and keep them under the console cover for the next time this switch goes out you will already have them on hand. Oh, and the Omran rep I talked to originally could not "confirm" the part they have is the exact same as Ford's, but hinted it was and Ford bought them from them. So, the $23 Ford part mentioned above is probably the same $5 microswitch from Mouser Electronics - just with the unique shaped switch arm if your gets bent or broken. Dan Edited August 29, 2020 by DD2000GT 4 Quote Link to comment Share on other sites More sharing options...
OoSockMonkeyoO Posted November 12, 2020 Report Share Posted November 12, 2020 It looks like I have this issue too on my 2015 Sport, and it drained my battery. The message popped up and wouldn’t let me even depress the brake to shift out of park and back in. The battery is currently charging. Will I be able to depress the break and clear this shift when the battery is charged fully, and if not, what can I do? Quote Link to comment Share on other sites More sharing options...
David Young Posted November 12, 2020 Report Share Posted November 12, 2020 6 hours ago, OoSockMonkeyoO said: It looks like I have this issue too on my 2015 Sport, and it drained my battery. The message popped up and wouldn’t let me even depress the brake to shift out of park and back in. The battery is currently charging. Will I be able to depress the break and clear this shift when the battery is charged fully, and if not, what can I do? Try wiggling the shifter to get the warning off. Try several times. You have to move the shifter down to remove everything to get to the bad switch (not sure on your 2015). Should be an 'over ride' for the shifter. A hidden button with a cover over it. Look at your owners manual, it should say something about it 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 13, 2020 Report Share Posted November 13, 2020 first incidence I have seen on a gen 2. 1 Quote Link to comment Share on other sites More sharing options...
David Young Posted November 13, 2020 Report Share Posted November 13, 2020 3 hours ago, WWWPerfA_ZN0W said: first incidence I have seen on a gen 2. I wonder if the switch is the same one or what the difference is. I would search it just for fun but I just mowed my yard and about to die :(. Not really die but tired, old age 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 15, 2020 Report Share Posted November 15, 2020 (edited) On 11/13/2020 at 2:06 PM, David Young said: I would search it just for fun but I just mowed my yard and about to die :(. Not really die but tired, old age That's what they make neighbor kids and riding mowers for! TSB 17-2219 does cover gen 2 Edges, so I suspect yes. GT4Z-3F988-B https://drive.google.com/file/d/1Fd9AruEDRLarbrLUFPUsHTma_sjLyGpY/view?usp=sharing prices have gone up substantially since the intial release. May be time to get your own Omron switch lol. Edited November 15, 2020 by WWWPerfA_ZN0W 2 Quote Link to comment Share on other sites More sharing options...
SJ 93 Posted November 23, 2020 Report Share Posted November 23, 2020 I have the 2013 for edge front wheel drive and the other day I stopped at a friends house and put the car in park but the vehicle never came out of gear, i had to drive it home with the shifter in the park position and just turn it off. Now the car's shifter is in park but the car still rolls when shut off. I am looking for any guidance. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 25, 2020 Report Share Posted November 25, 2020 a) use the parking brake when parked b) search the forum for shift switch issues. Ford has issued an updated switch to fix the "shift to park" warning, which can also drain the battery over time. 1 Quote Link to comment Share on other sites More sharing options...
lenamia465 Posted April 24, 2021 Report Share Posted April 24, 2021 Our 2014 Edge Limited with 60,000 miles was giving the same message: "Transmission not in Park. " Bought the Mouser electronics part (bought two of them just in case) and swapped out the old switch with the new one. Tested it a few times before I put everything back together. Thanks for the post and great step by step instructions!! Quote Link to comment Share on other sites More sharing options...
David Young Posted April 24, 2021 Report Share Posted April 24, 2021 (edited) Wrong Thread Sorry Edited April 27, 2021 by David Young Quote Link to comment Share on other sites More sharing options...
Scott'sSEL Posted January 19, 2022 Report Share Posted January 19, 2022 Has anyone had this issue, with key start ignition? Or only push to start? I called Ford today they said the TSB is only relevant for push to start ignitions. But I am having the same exact issues, as that TSB states : shift to park, shift indicator lights remain on when I exit the vehicle. Key gets stuck in the ignition. I was told I would have to replace the whole shifter probably, or it may be the gear selector on the side of the transmission. But it won't have anything to do with this switch. Somebody please chime in to help me.. Thank you.. Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 19, 2022 Report Share Posted January 19, 2022 8 hours ago, Scott'sSEL said: Has anyone had this issue, with key start ignition? Or only push to start? I called Ford today they said the TSB is only relevant for push to start ignitions. But I am having the same exact issues, as that TSB states : shift to park, shift indicator lights remain on when I exit the vehicle. Key gets stuck in the ignition. I was told I would have to replace the whole shifter probably, or it may be the gear selector on the side of the transmission. But it won't have anything to do with this switch. Somebody please chime in to help me.. Thank you.. The TSB (Link to the TSB), also states "or unable to remove the integrated keyhead transmitter (IKT)", so it does include vehicles with key start ignition. 3 Quote Link to comment Share on other sites More sharing options...
