Kona11 Posted January 15, 2017 Report Share Posted January 15, 2017 I have recently picked up my 2011 edge sport. I am the 2nd owner and have a clean slate to work with. Im looking into replacing the halogen lights with led. Has anyone done this that can give me pointers on it and things that i will encounter? Thanks Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 16, 2017 Report Share Posted January 16, 2017 This thread may be of some help to you: http://www.fordedgeforum.com/topic/12851-brightest-leds/ Quote Link to comment Share on other sites More sharing options...
addison21 Posted March 27, 2017 Report Share Posted March 27, 2017 Although LEDs are a lot better than halogens, HID is the best upgrade. Quote Link to comment Share on other sites More sharing options...
TheWizard Posted March 27, 2017 Report Share Posted March 27, 2017 It depends... by halogen it sounds like you're looking to replace the headlights (since the other bulbs such as taillights and turn signals are not halogen). In that case, addison21 is correct, HIDs will provide better bang for the buck. Really good LED headlight bulbs are expensive ($200 or more). They need to have adjustable collars, strong and reliable cooling, and lots of power to be better than OEM halogen projectors. On the other hand, replacing the miniature incandescent bulbs with their LED equivalents is quite simple. Some types will work better than others because of the reflector designs. For example, SMD tower LED bulbs tend to work best for the turn signals because the larger number of LEDs fills out the lamp better. But high power CREE bulbs often work well for tail/brake lights even though they only have a couple of LEDs. Always get LED bulbs that match the color of the lens (i.e. red LEDs for tail lights) except of course clear turn signal lenses would call for amber LEDs. You likely will need load resistors for the turn signals to prevent hyper-flashing. 1 Quote Link to comment Share on other sites More sharing options...
