Joel2010 Posted January 12, 2017 Report Share Posted January 12, 2017 So I bought aftermarket headlamp assemblies for my 2010 ford edge, they look great, only problem is they are not bright enough for where I live. I have the assemblies from carid.com, originalfactory assemblies call for two bulbs, a hi and a low (H11 and 9005) these aftermarket ones go to a single H11 bulb and when you activate high beams a apperture opens to widen the beam.... Problem is its still a low beam. Im wondering if anybody has used LEDs or HIDs with this aftermarket assemblies or if anybody knows how to get a 9005 bulb onto a H11 retainer ring to install in the housings? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 13, 2017 Report Share Posted January 13, 2017 Like this? https://www.amazon.com/PartsSquare-female-Convert-Pigtail-Harness/dp/B014STATG8 Here's a link on how to do it. http://www.toyota-4runner.org/5th-gen-t4rs/150621-how-headlight-bulb-conversion-h11-h9-9005-9011-a.html Please note that this is NOT STREET LEGAL. If you proceed, please make certain that your headlights are carefully aimed for the sake of on-coming drivers. 1 Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted January 13, 2017 Report Share Posted January 13, 2017 H9 can be modded to fit into an H11 housings, H9 is WAYYYY brighter also 1 Quote Link to comment Share on other sites More sharing options...
Joel2010 Posted January 13, 2017 Author Report Share Posted January 13, 2017 Thanks so much everyone for your comments and ideas. Ill give it a go and hopefully theyll fit Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 13, 2017 Report Share Posted January 13, 2017 H9 can be modded to fit into an H11 housings, H9 is WAYYYY brighter alsoNot to dispute, I've read that on some cars it crazed the metalized reflector inside the headlight. More light, but more heat. Did you see any negative effects when you installed them? Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted January 14, 2017 Report Share Posted January 14, 2017 Not to dispute, I've read that on some cars it crazed the metalized reflector inside the headlight. More light, but more heat. Did you see any negative effects when you installed them? Too early to tell but, Fusion will eventually be retrofitted anyway so it's not really a long term issue with my setup Quote Link to comment Share on other sites More sharing options...
