Removing cat coverter permanently
T-Fade
Sorry I didn't mean specifically from a 2008 3.5. I was just saying that it's easy to get 400 hp out of a stock factory converter and in some cases like the Mustang 5.0 you can add a supercharger and get 700 without changing the factory cat (as far as I know). So you don't have to remove the cat to make big power.
One other thing to consideris if you trade the car in with a dealer, they will reduce the value of the car by what it costs to bring it back into your state's emission standards. (At least that's true for my state of Indiana.) Ok if private sale, but dealers are required to maintain emmision standards.
  On 1/12/2017 at 10:51 AM, Ntrain2k said:
It will still adjust the fuel mixture accordingly and the engine will live just fine.
He will get a CEL for cat inefficiency though. That would have to be programmed out.
It's not worth the hassle. I suppose he could thread the post cat O2 sensor into the exhaust spool piece and have partial control of the mixture. That would be better than going open loop on the fuel mixture control loop.
Theoretically, the engine is more efficient (and produces the most power) when the O2 sensors (pre and post) are part of the fuel ratio control. The pulse duration of the injectors and the spark plugs are controlled by the input signal received from the O2 sensors. Those sensors detect whether complete combustion is taking place and adjust timing and pulse duration to achieve as complete a burn as possible.
Agreed that you may get a smidge more power by running slightly lean, but it raises cylinder head temperature and may cause detonation.
The best option is high flow cats as akirby suggests, or maybe a dual exhaust like on the 3.7 sport.
