eddyecpowell Posted January 9, 2017 Report Share Posted January 9, 2017 (edited) , Edited March 22, 2017 by eddyecpowell Quote Link to comment Share on other sites More sharing options...
gjb89 Posted January 9, 2017 Report Share Posted January 9, 2017 Road noise as in tires? Quote Link to comment Share on other sites More sharing options...
eddyecpowell Posted January 9, 2017 Author Report Share Posted January 9, 2017 I suspect the tires since the vehicle is new. It feels like eighter a balance or alignment issue Quote Link to comment Share on other sites More sharing options...
gjb89 Posted January 9, 2017 Report Share Posted January 9, 2017 My alignment was all out of wack when we purchased ours new. Tell them your steering wheel is crooked and you want it fixed. If you put too many mikes on it they will not cover the alignment, atleast that's what my dealership said. 1 Quote Link to comment Share on other sites More sharing options...
eddyecpowell Posted January 9, 2017 Author Report Share Posted January 9, 2017 I'm going to call Monday. Just don't know why they have to give you such a hard time to just check the alignment! 1 Quote Link to comment Share on other sites More sharing options...
gjb89 Posted January 9, 2017 Report Share Posted January 9, 2017 You can take it to another dealership too. Quote Link to comment Share on other sites More sharing options...
eddyecpowell Posted January 9, 2017 Author Report Share Posted January 9, 2017 Good idea Quote Link to comment Share on other sites More sharing options...
gjb89 Posted January 9, 2017 Report Share Posted January 9, 2017 When I got fed up with mine I went else where. Quote Link to comment Share on other sites More sharing options...
eddyecpowell Posted January 9, 2017 Author Report Share Posted January 9, 2017 I'll try one more time. Don't know why it's such a big deal to put it on the machine. The numbers will prove themselves. Just don't feel like arguing for two hours!!! Quote Link to comment Share on other sites More sharing options...
Burrcold Posted January 9, 2017 Report Share Posted January 9, 2017 My alignment was all out of wack when we purchased ours new. Tell them your steering wheel is crooked and you want it fixed. If you put too many mikes on it they will not cover the alignment, atleast that's what my dealership said.Same here. I told them my steering wheel wasn't straight so it forced them to do an alignment. Low and behold there were all sorts of issues they had to correct (mainly the toe setting). 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 9, 2017 Report Share Posted January 9, 2017 You can also ask to test drive another 2016 Edge (with the same wheel size) to confirm that your Edge really has an issue. Quote Link to comment Share on other sites More sharing options...
eddyecpowell Posted January 9, 2017 Author Report Share Posted January 9, 2017 That's a good idea too! Thanks for the ideas!!! Quote Link to comment Share on other sites More sharing options...
eddyecpowell Posted January 14, 2017 Author Report Share Posted January 14, 2017 Had a family member drive the car, and found no issues. Said it's the tires, they are just cheap tires. Also read reviews on the Pirelli scorpions, and they all talked about excessive road noise. I went back to the Ford dealership today and they gave me a really hard time. I decided to just replace the tires. Really irritated to have to by new tires for a car with only 1400 miles. the road noise is just driving me crazy!!!! Quote Link to comment Share on other sites More sharing options...
Burrcold Posted January 14, 2017 Report Share Posted January 14, 2017 Had a family member drive the car, and found no issues. Said it's the tires, they are just cheap tires. Also read reviews on the Pirelli scorpions, and they all talked about excessive road noise. I went back to the Ford dealership today and they gave me a really hard time. I decided to just replace the tires. Really irritated to have to by new tires for a car with only 1400 miles. the road noise is just driving me crazy!!!!You should have at least brought them to a tire shop and had them balanced. Cheap fix if that's all it was compared to buying all new tires! What kind did you end up getting? Quote Link to comment Share on other sites More sharing options...
akirby Posted January 14, 2017 Report Share Posted January 14, 2017 Balancing doesn't normally fix noise. You should be able to sell them pretty easily. Quote Link to comment Share on other sites More sharing options...
Burrcold Posted January 14, 2017 Report Share Posted January 14, 2017 Balancing doesn't normally fix noise. You should be able to sell them pretty easily.Unbalanced tires can definitely cause a humming noise at higher speed, I've experienced it myself. The OP also said there was slight shaking in the steering wheel which is definitely a sign of unbalanced tires. Even if they were bad tires, it's a cheap check before going out and buying a whole new set. But hey, to each their own. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 14, 2017 Report Share Posted January 14, 2017 In that case I agree it would be wise to have them balanced first. I missed the steering wheel shake. Quote Link to comment Share on other sites More sharing options...
eddyecpowell Posted January 14, 2017 Author Report Share Posted January 14, 2017 I did have them balanced, also had them check the alignment. One tire was out of balance, but did not solve the problem. I then checked the reviews on the pirelli scorpion verde all season, and they described my exact problem. Decided on Michelin premier gtx. They should be in in a couple of days. I have heard really good things about these tires. I had Michelin tires on my last Edge, and it drove really nice! 1 Quote Link to comment Share on other sites More sharing options...
Nuclear1 Posted February 4, 2017 Report Share Posted February 4, 2017 Had a family member drive the car, and found no issues. Said it's the tires, they are just cheap tires. Also read reviews on the Pirelli scorpions, and they all talked about excessive road noise. I went back to the Ford dealership today and they gave me a really hard time. I decided to just replace the tires. Really irritated to have to by new tires for a car with only 1400 miles. the road noise is just driving me crazy!!!! I've got 6k miles on mine and have what sounds like tire noise. The dealer said they can find nothing mechanically wrong. I drove one on the lot with the same mileage and it had the same noise. My noise wasn't there a month ago. Did the new tires fix your problem? What were your original tires and what did you replace them with? Quote Link to comment Share on other sites More sharing options...
Mgavin1985 Posted February 14, 2017 Report Share Posted February 14, 2017 Could be tie rod issue. If too much play in tierod you will be bad vibration on highway starting around 35mph and will get worse as mph go up. It's good that u start with tire balancing because of price and then work way through suspension. If not that jack one corner of your Edge up and tire to see if there is any play in wheel if so I may have ball bearing issue. Both tie rod and bearing issue are a couple hundred to fix at garage Quote Link to comment Share on other sites More sharing options...
Mgavin1985 Posted February 14, 2017 Report Share Posted February 14, 2017 Only 6k on it nothing should be worn??? Hopefully not a lemon good luck with the fix Quote Link to comment Share on other sites More sharing options...
Mgavin1985 Posted February 14, 2017 Report Share Posted February 14, 2017 Also maybe do wheel alignment or have local tire shop instead of dealer do alingment maybe dealer is giving u run around because they think only 6000k nothing wrong and trying to get u out the door. 1 Quote Link to comment Share on other sites More sharing options...
eddyecpowell Posted February 14, 2017 Author Report Share Posted February 14, 2017 I have had the wheels balanced, replaced the tires with Michelin's, had the car 's alignment checked and still get a noise at around 40-45 mph. I'm going to take it back to the dealership soon for first oil change and have the technician drive with me. It's not a loud noise, so not sure if they will hear it. It's just really annoying, and I do not want to ruin new tires. I keep checking other forums to see if anyone is having the same issue. Cannot believe it would be transmission related in a new car? Quote Link to comment Share on other sites More sharing options...
Mgavin1985 Posted February 15, 2017 Report Share Posted February 15, 2017 well once you get it figured out put the post up. best of luck and hopefully it doesn't hit you in the wallet too bad. Quote Link to comment Share on other sites More sharing options...
eddyecpowell Posted February 16, 2017 Author Report Share Posted February 16, 2017 Got an appt next Friday, and yes I need all the luck I can get. Getting really frustrated with this dealership and car Quote Link to comment Share on other sites More sharing options...
