Anyone have suggestions on how to minimize the speaker and door panel rattles on the 15+ edges. I have had the dealer take a look and their fix was to turn the bass and mid-range down to negative 3 (LLLLLLOOOOOOOOLLLLLLLL) Everything rattles at 30% + volume with the sound settings all at zero (or neutral). Shit shouldn't rattle like this from the factory, with factory sound settings.
In the spring I plan on tearing apart the door panels and stuffing sound deadening materials everywhere, and trying to rubber tape the speakers points of contact with surfaces etc.
  • 3 months later...
I found the dynamat at a semi decent price on amazon, I think ill use it with the sound insulation if I can get it. Linus Tech (in Vancouver) used the jean insulation to deaden their server room and it appeared to work well so I assume it should work well on a vehicle.
My advice is you generally get what you pay for, but I don't have any direct experience with this stuff.
What doesn't rattle on this car. Most likely the retainment clips need to be replaced.
Haha, 2 boxes of trim panel clips just came in on Thursday and I picked up 5 rolls of felt tape. Everything will be covered or replaced by the end.
