Outside Temperature Reading Not Reading Correctly Inside Vehicle
Having issues with the exterior temperature readings on the interior screens. Ford has replaced the sensor, however, it is still giving readings that are way off of what the actual outside temperature is. e.g. real outside temperature is -1C, yet the interior readings on both screens are reading anywhere from +30C to 5C and fluctuating in between.
Anyone else have this issue or a repair suggestion?
Thanks
