MOLSON Posted December 21, 2016 Report Share Posted December 21, 2016 The touch screen in my wife's 2013 Edge limited stopped working. The screen still works its just the touch that will not work. The back up camera comes on when it is shifted into reverse. But we can not use any function on the screen like the heated seats or changing radio stations. Any ideas??? We are in Wisconsin and she misses those heated seats! Quote Link to comment Share on other sites More sharing options...
candurin Posted December 21, 2016 Report Share Posted December 21, 2016 Did you reboot/restart the sync system? You can always remove and reinsert the cable bundle that goes into the fuse panel in the driver's kick panel under the steering wheel. I've done this many times without issue. System will reboot itself ("perform maintenance"). 1 Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted December 22, 2016 Report Share Posted December 22, 2016 The touch screen in my wife's 2013 Edge limited stopped working. The screen still works its just the touch that will not work. The back up camera comes on when it is shifted into reverse. But we can not use any function on the screen like the heated seats or changing radio stations. Any ideas??? We are in Wisconsin and she misses those heated seats! Hey MOLSON, Are all the options such as, Phone and Entertainment inoperable? If so, try performing a key cycle. Once the engine has been running, turn off the vehicle and remove the key. Open the drivers side door for 30 seconds. Then, close the door and restart the vehicle. Keep me posted! Cara Quote Link to comment Share on other sites More sharing options...
Mustafaa Posted September 22, 2017 Report Share Posted September 22, 2017 I'm having the same issue. I bought mine last month and have tried unplugging the cable in the fuse box and reseating the fuse. I even removed the screen and SO IN and reinstalled and still the screen is unresponsive to touch. Radio can only be operated from the steering wheel controls. Backup camera works but nothing else. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 22, 2017 Report Share Posted September 22, 2017 Couple of ideas. Try pulling out the ACU, disconnect the screen and check the connector for corrosion. Second is to try a master reset. Normally you would need the screen, but I ☆think☆ this can be done through the AUX button and sterring wheel controls. http://ford-life.com/2012/07/19/how-to-reset-microsoft-sync/ Quote Link to comment Share on other sites More sharing options...
Mustafaa Posted September 23, 2017 Report Share Posted September 23, 2017 Couple of ideas. Try pulling out the ACU, disconnect the screen and check the connector for corrosion. Second is to try a master reset. Normally you would need the screen, but I ☆think☆ this can be done through the AUX button and sterring wheel controls. http://ford-life.com/2012/07/19/how-to-reset-microsoft-sync/ Quote Link to comment Share on other sites More sharing options...
Mustafaa Posted September 23, 2017 Report Share Posted September 23, 2017 Thanks. I have already removed the MFT and reconnected to the APIM and same issue. I have a 2013 so no aux button. Quote Link to comment Share on other sites More sharing options...
aggie8387 Posted June 19, 2018 Report Share Posted June 19, 2018 I have a 2012 Ford Edge. Touch screen would randomly decide to not work for a day or so. Now it's been out for a week. No function at all. Any ideas other than going to the dealer? Quote Link to comment Share on other sites More sharing options...
b516950g Posted April 19, 2021 Report Share Posted April 19, 2021 (edited) I know this is an old topic. But looking through it can not find my exact problem. I get the message " temporarily lost communication with the climate control system" on ever startup. Also none of the ac controls work and the MFT is unresponsive. I can temporarily fix the the problem with resetting the BCM before I start the car. But this only last until the next restart. Any idea's? Thanks Edited April 19, 2021 by b516950g Quote Link to comment Share on other sites More sharing options...
b516950g Posted April 19, 2021 Report Share Posted April 19, 2021 2013 ford edge Sel Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 19, 2021 Report Share Posted April 19, 2021 2 hours ago, b516950g said: 2013 ford edge Sel Welcome. To save yourself posting that each time, you can add location, Model and Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ Quote Link to comment Share on other sites More sharing options...
