PTU/transmission spline shearing
Alex Bordeleau
Hey everyone, i own a Mazda CX9 which has the same problem you guys are experiencing with your Edge. I would like to know if someone here found a solution to this, my problem is the gearing in the transmission chewed up due to problably the PTU being too stiiff with that oil transformed into grease.
Even if i buy a new PTU, it won't be of any use since the transmission splines are dead and Mazda won't sell just the differential inside the transmission, i have to change the whole transmission... which probably cost more than what my truck is worth.
Anyone found a machine shop that can rebuild the teeth? Is this even a problem with you Edge transmission or is it only happening on the Mazda side?
thanks
DD9E00E1-79F3-4410-81E1-D1EF2C9D1947_zps
