11 Edge 3.5 P0012
pickardracing
Somewhat early to have this issue! You can try unplugging and reseating the solenoid connectors. Then disconnect the battery for 30 minutes/clear the code. See if the code comes back.
If it does, then at the very least both solenoids are likely to be needing replacement. What type of oil/filter do you run in the Edge, and what are the change intervals?
Change the oil and go with an oil filter that is at least 25 micron or better filtration and a full synthetic 5W20 chose the type made from natural gas to get the best oil. Run that after resetting the DTC's
If this does not correct the issue then new VCT's are in order as you can not with certainty clean them for re-use.
