Misfire under heavy acceleration
Bryan003
Inspect all the plugs and coils carefully. If not replacing the #1 coil, move the 123 coils to 456 and the 456 coils to 123. It is suspected that extra heat trapped in Bank 1 degrades those coils faster. So even if they are working fine now, you could prolong overall service life with this swap. One thread with useful info on spark plug replacement (might be a bit different for the 2011-14 3.5s on exact details):
http://www.fordedgeforum.com/topic/8724-sparkplug-replacement-job-info-with-photos/
Ā
The misfire can also be caused by a dirty injector, so run some Techron Concentrate Plus or BG 44K cleaner through the tank first. Winter fuel isn't the best to begin with and using fuel from non-top tier gas or not-so-busy gas stations can result in water & contaminants in the fuel. Definitely, cylinder 1 is a weak spot, but it is also at the end of the fuel rail, where such contaminants tend to accumulate.
