Horrible grinding, rattle and dragging sound.
rtmad21
Hello all,
I have a 2010 AWD with 85,000 miles. For about a week or so i would get a random but strong vibration maybe once a day but could not figure out where it was coming from. Yesterday while driving in a parking lot (<10 MPH) I heard a loud grinding sound followed by what sounded like a dragging tailpipe. Now, when driving forward i hear the same sounds plus a loud rattle almost like a rock in a can being shaken. Today when I tried to move the car it was gone until I made a turn, then it came back. Also, this only happens when moving forward, no issue in reverse.
Any thoughts?
  • 4 weeks later...
  • 4 weeks later...
2009 Ford Edge limited AWD - 80k on the clock. I'm having the exact same issue. Any solutions to this problem? I noticed it too in a parking lot going less 5mph. On,y happened when I made a left turn at low speeds. Almost sounds like a fan blade was hitting something. Very clunky sound and I'm getting the vibration as well on take offs. I thought maybe a wheel bearing issue, but the clunky and noise from the turn got me thinking otherwise.
Yes thats what it smells like. And yes, you can inspect it while the edge is on jackstands, you will want good lighting though. It is on the passenger side, and the leak will likely be from the vent atop the ptu. The grease will be dark brown in color, thick, and smelly.
Reference thread:
http://www.fordedgeforum.com/topic/10914-ptu-leak-failures/
Edited by WWWPerfA_ZN0W
