Wes Myers Posted December 5, 2016 Report Share Posted December 5, 2016 (edited) Good evening, everyone. I'm trying to figure out how to hook up a powered Rockford Fosgate 12" sub that I bought for my girlfriend and her Ford Edge as a Christmas present for her. I've tried searching Google and there seem to be these amplifier interface connectors that allow you to plug in the factory head unit to while providing a set of RCAs, presumably to hook up the powered sub with. But every one of these that I've found doesn't seem to be for the 2013 Edge. I don't know a whole lot about car stereos and such but finding some kind of adapter like this seemed easy enough for me to install on my own for her. Is there anything like this for the 2013 Edge? Or some kind of alternative method I could use that would be easy and practical enough for the layman? Thanks, everyone. WM Edited December 5, 2016 by Wes Myers Quote Link to comment Share on other sites More sharing options...
Helbing Posted April 7, 2020 Report Share Posted April 7, 2020 Ever figure this out?? Quote Link to comment Share on other sites More sharing options...
Donnielynn1 Posted April 8, 2020 Report Share Posted April 8, 2020 Check this video out, relevant parts start about 8:30 in, there's no adapter available so you'll have to tap into the factory speaker wires for signal. https://www.crutchfield.com/S-cbbyNr1Qdri/learn/adding-an-amplifier-to-a-factory-stereo.html Quote Link to comment Share on other sites More sharing options...
LTSRIDE Posted June 17, 2021 Report Share Posted June 17, 2021 On 12/4/2016 at 6:29 PM, Wes Myers said: Good evening, everyone. I'm trying to figure out how to hook up a powered Rockford Fosgate 12" sub that I bought for my girlfriend and her Ford Edge as a Christmas present for her. I've tried searching Google and there seem to be these amplifier interface connectors that allow you to plug in the factory head unit to while providing a set of RCAs, presumably to hook up the powered sub with. But every one of these that I've found doesn't seem to be for the 2013 Edge. I don't know a whole lot about car stereos and such but finding some kind of adapter like this seemed easy enough for me to install on my own for her. Is there anything like this for the 2013 Edge? Or some kind of alternative method I could use that would be easy and practical enough for the layman? Thanks, everyone. WM Just use the high level input and tap into the wiring at the factory amp, which is located right where you will be putting your aftermarket sub & amp, I'd assume. It's super easy!! You're going to be right there anyways when you disconnect the factory sub, since you'll obviously no longer need it. All it is doing is adding distortion to your system. Quote Link to comment Share on other sites More sharing options...
