2011 SEL series 100 remote start
Trying not to beat a dead horse here, but I've looked through all post in the sub forum with no luck.
Ive purchased # BC3Z-19G364-A and # BT4Z-19G366-A
I took the rear 1/4 panel off, and plugged the antenna into hopefully the correct plug, it fit and snapped locked into place.
see my pictures for further confirmation. I already installed the hood switch.
My next question is, what do I do now? Take it to the dealer? Do I have everything I need to get it up and running?
Did you buy the remote start keys? If so take them to your dealer and ask them to program them.
If not here is the part number for the key with 5 buttons.... DA8Z-19G364-A (power hatch/ trunk)
Here is the part number for the key with 4 buttons BB5Z-19G364-A (sans power hatch/ trunk)
There is a guy around here who goes by the name of Benny from Levitown. He can sort you at a good price!
Eco... looks as though you need to make sure that under BCM as built, the value of 726-19-01 should be 0148 to enable remote start.
Then once write and reboot. Then you should be able to enable remote start under IPC (as built), which will give you the options in the left hand instrument cluster.
I had mine done by ford, but I verified that is the value I have in my vehicle.
Here's some additional info (again, I haven't done this, just passing along what I find with my staggering google skills):
"Y"'s get changed...
Factory/OEM Remote Start (Main System):
726-22-02 (2014+ MY) (BdyCM)
xxxY xxxx xxxx
0 (Disabled)
1 (Enabled)
726-32-01 (2013 MY) (BdyCM) - Note: Untested on 2013
xYxx xxxx
0 (Disabled)
1 (Enabled)
Factory/OEM Remote Starter Dashboard Controls:
720-02-02 (2013+ MY) (IPC)
xxxx YYxx
00 (Disabled)
FA (Enabled w/Climate Control) - Note: This setting can be FD on some newer IPC's (2015+)
Factory/OEM Remote Starter Parking Lights:
726-41-02 (2014+ MY) (BdyCM)
xxxx xxxY xxxx
1 (Enabled - Default)
0 (Disabled)
Reference: http://www.2gfusions.net/showthread.php?tid=4573
