AC Not Cold When Outside Temps are below 62F
So here is the scenario:
59/60 degrees outside Temp, inside temp set at 68, actual inside temp 75+, AC set on auto ups the Fan, but the air is barely colder than the set point. Interior never cools down.
Tried hitting MAX AC which sets temp to LO/No Temp, and the recirc turns on, and the fan ramps up, but the air coming out is no colder.
Set back to auto, and turn temp down to LO, still air is barely cool.
It has happened several times in the past few weeks. When it was hot the other week the AC would run you out of the car it was so cool.
All other vehicles, if I set the Auto system to the lowest temp, or tured MAX AC on, I got cold air, not in my 2016 Sport. WHY??? I am very hot natured, and this is REALLY bugging me.
Edited by Ray Heath Jr
Also have them check that the BCM calibration is up to date. This is based on CSP 12B43 for the 2013 Taurus.
Thanks guys! Leaning towards the coolant being low. Played with it last night, after putting stock program back on ECU. It try's to adjust based on the set temp, so I think the sensor is good. Just think it's not cooling.
