oldtreker Posted November 15, 2016 Report Share Posted November 15, 2016 My remote start seldom works. I go thru the standard procedure and nothing happens. I do get the red LED on the fob but nothing else Checked the dash display and it's set to work for 10 minutes. Mine is a 2016 2.0. 5K miles Google shows older owners have this problem also. Thanks Quote Link to comment Share on other sites More sharing options...
jmr061 Posted November 15, 2016 Report Share Posted November 15, 2016 If you currently have this problem disconnect the battery for 15 seconds and reconnect. This will likely solve it however if this a reoccurring issue then it will probably happen again. You don't have anything hooked up to the diagnostic port do you or access the vehicle programming via the diagnostic port? 1 Quote Link to comment Share on other sites More sharing options...
oldtreker Posted November 23, 2016 Author Report Share Posted November 23, 2016 thanks I was trying to avoid the battery disconnect, don't want to reset everything. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted November 23, 2016 Report Share Posted November 23, 2016 thanks I was trying to avoid the battery disconnect, don't want to reset everything. What do you believe it resets? Quote Link to comment Share on other sites More sharing options...
chefduane Posted November 23, 2016 Report Share Posted November 23, 2016 Actually, that would be good knowledge to have. What exactly DOES a battery disconn reset? I would assume all radio presets and settings (fade, balance...) and also any destinations/routes saved in Navigation, also probably climate settings? Anything else? Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 23, 2016 Report Share Posted November 23, 2016 (edited) Actually, that would be good knowledge to have. What exactly DOES a battery disconn reset? I would assume all radio presets and settings (fade, balance...) and also any destinations/routes saved in Navigation, also probably climate settings? Anything else? Radio presets & its settings don't reset, also destinations/routes saved in Navigation should not. Climate settings? what settings? you only have the last setting and it will reset to default set temp but you just change normally. Anything else? The left display settings in the instrument cluster will reset some settings like the "menu memory will revert to default with no memory, enhanced trip computer will revert to the simple setting and the vertical tach display will revert to not being shown. Also the miles to empty might change to be based on a set default mileage instead of your actual average for the past few hundred miles. The engine idle & transmission shift calibrations will also reset, but they adapt quickly after driving. Actually it is a good thing to do, disconnecting the battery every once in while to reset the car's electronics. Just like you PC or smartphone. Edited November 23, 2016 by omar302 1 Quote Link to comment Share on other sites More sharing options...
