No heat drivers side.
Hello everyone. On our 2013 edge with dual climate control, there is no heat on the driver side, only cold. Hot and cold work on the pass side. I took of the blend door actuator, on the drivers side. I can easily move the linkage and make heat work for the drivers side. So my question is, did i take off the culprit (the drivers side blend door actuator)?
On the actual actuator itself, i will break the white plastic arm off before it will move, so to me it would be the problem.
What brand to get? autozone, orelies, rocauto.......
Thanks in advance.
I am having the same issue. Hot on passenger side, cold on drivers side while the heater is on. Where is the drivers side blend door actually located? I read about unplugging it and plugging it back in, but I'm not sure where it is to disconnect it. Does anyone happen to have pictures of it?
