Pre-wash Gun
Anyone else using one of these foam guns? I purchased one of these about a month ago and find it very useful especially for getting road grime off and loosening up the bugs on my front end. The particular model i'm using is the Chemical guys version. This is a direct hose attachment that does not require a pressure washer.
Links to the products
Gun
http://www.amazon.com/dp/B00F5MCL14?psc=1
High suds soap (smells amazing)
http://www.amazon.com/dp/B009OTW646?th=1
c7cf152f-8c90-488f-adb6-69be0aacdb81_zps
I use this one with my pressure washer:
https://www.aliexpress.com/item/Snow-Foam-Lance-Foam-Nozzle-Lavor-New-Type-compatible/1079982643.html
Works great, The key, of course, is having the right soap - Chemical Guys have great soaps but Maguire's Gold Class works well and is available everywhere.
If you get a pressure washer foam gun, make sure it will fit your connector, there are different types.
