ForScan Crew: Can the IPC be programmed to do the cluster on 2012-2014 Edges?
The 2011 Edge Sport (and maybe other models - I've only seen a sport do this) does a cluster sweep at startup, where the speedo, tach, temp, and fuel gauges all max out and return to 0 or their respective values. It seems like Ford removed this from 2012+ models.
Why?
But more importantly, can we program this "feature" back, using ForScan? I like it, and I want my 2013 Edge Sport to do it.
