only126db Posted October 17, 2016 Report Share Posted October 17, 2016 ABS and Traction control light came on brakes would lock up and were very grabby, lights went off by themselves, brakes acted fine but when checking codes I had two pending codes (forget what they were)... Took it to dealer they diagnosed it as a bad ABS Control Module and Hydraulic Control Assembly and quoted me around $2500 to repair it....Now the problem is they must have cleared the codes because I have had no pending codes in a month and the lights have never come back on.....The guy at the dealer said it will not show a pending code unless the actual ABS or Traction Control light illuminates.... Does this sound right? The pending code thing... Also usually wouldnt a dealer 'not' clear a code like that due to liability issues unless they repaired it? Quote Link to comment Share on other sites More sharing options...
akirby Posted October 17, 2016 Report Share Posted October 17, 2016 My guess is it was a flaky sensor/wiring and not a problem with the control module but that's just a guess. If it was a real problem the light would have come back on immediately. I would take it to a different dealer if the problem reoccurs that way you'll have 2 opinions. But this is usually a sensor or tone ring. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 18, 2016 Report Share Posted October 18, 2016 ^ X2. Wheel speed sensors and tone rings are usually the culprit parts on the Edge. I'd have those carefully inspected at a reputable independent shop. I take it no brake work was done recently? 1 Quote Link to comment Share on other sites More sharing options...
only126db Posted October 28, 2016 Author Report Share Posted October 28, 2016 ^ X2. Wheel speed sensors and tone rings are usually the culprit parts on the Edge. I'd have those carefully inspected at a reputable independent shop. I take it no brake work was done recently? Yes, entire front suspension is new besides rack, brakes new all around...tires new, end links in rear new... Quote Link to comment Share on other sites More sharing options...
