Fuel filler neck problem
aroo1986
Have a 2012 ford edge and recently when pumping gas the pump will constantly click off every time I squeeze the pump handle. It clicks off as if I was topping off the tank which I am not. If I squeeze the handle only a little the pump won't click off its when I squeeze the pump handle fully it clicks off. Wondering if anyone else has had a problem similar and if this is due to not properly realising vapor or the charcoal canister going bad? Or maybe an issue caused by something else do the filler necks on these go bad? Any information would be a great help. Thanks.
