Transmission Shift Solenoid
Viktor Breeden
So I bought my 2010 MKX a month ago and recently started noticing a hissing noise when I'd stop at a drive thru. I'd change gears to see if it would stop and it does more in reverse than drive. I took it into the stealership yesterday and told me it's the transmission shift solenoid, is this a common problem with these? She also has a extended crank as well. This is the 2nd Ford I've owned my first one was a 99 ZX2 and had no problems with her.
