Heat Only on Driver Side
My wife has a 2013 Edge SEL, this morning I went to get her gas and turned on the window defrost. Only the Driver side was getting heat. Duel temp was selected and both sides set at 80. I messed with it for a bit but I am only getting hot air from the vents, dash and floor on the driver side. Passenger side is blowing cold air. Is there a sensor that might be bad or maybe the blend door? HELP !!!
Yup, one BDA on driver side, one on passenger side. Also check cabin air filter, coolant level and A/C refrigerant level (yes it does weird things with airflow). Could be the HVAC module also, but less likely.
Thanks for the pdf, it will make life much easier.
  • 8 months later...
