Dash kit...
I'm very tempted in getting a gloss black dash kit for my '16 Titanium. I don't plan on using all the parts included in the kit, just the ones around the shifter, the small storage compartment door, heated seats and radio and heater controls and last, the touch screen surround piece. (I'm including a picture of the pieces I'm talking about below)...There is already some factory-installed gloss black pieces on the console and doors (where the switches are) but I find that the area I just described above would be a nice addition which would blend-in with the factory pieces...
What do you guys think?
Claude. :)
Vinyl wrap it. I'm sure you will save quite a bit going that route plus it won't look cheap!
Thanks for the suggestion…but 1st, I don't know anyone in my area doing this and 2nd, I don't want to remove the parts from the dash… and 3rd…why do you say that it would look cheap? I've done a complete kit in my '02 Thunderbird (see picture) and it looked terrific, looked original to the untrained eye!...
Claude.
Some kits that I have seen are very thick, with a lot of the buttons on the 15'+ edges being flush mounted I think it would look bad with the buttons recessed because of an overlay. To each their own. I will say the console trim on the Ford Edge is the easiest trim I have ever had to disassemble or assemble.
I ordered only the pieces I showed in the initial post and am waiting for them to come in. I'll post some pictures when they're installed. I didn't want to buy a whole kit because they include so many parts that if you install all of them, it looks too obvious that they've been added-on. :( I just wanted to do the center console... ;)
Claude.
  • 3 months later...
  • 4 weeks later...
Wow, that carbon fiber wrap does look amazing! That is definitely the route I would go as well. Excellent work on the upgrade dweiss22!
Thanks revitus.. it was relatively easy to do once all the dash parts were removed. I had a custom layout done by Rvinyl. Had to get it done twice because they made it wrong the first time. But all ended well. Thanks again for the positive response.
